Hi Roy,
Please check the attached SPI PE project, it is the CW project for KL25.
You can refer to this project add the SPI PE module, then add the according code.
Wish it helps you!
Kerry
Hello Kerry.
Thank you for your help.
What means CW?
And where is the attatched project?
Roy
Hi Roy,
CW is the codewarrior IDE.
About the project, you can refer to the official KL25 CW project:
https://www.nxp.com/downloads/en/lab-test-software/KL25_SC.exe
The project folder:kl25_sc_rev10\klxx-sc-pex\projects\spi_demo
Wish it helps you!
Kerry
