Some time ago, Mark Peterson asked about a Mfgtool-sd. An iMX6 device would boot from an SD card load the tool that would burn an os on the device eMMC.
Is this tool available?
Thank you
Hi Nicolas
I am afraid such tool is not available, for programming images provided only mfg tool found on :
Thank you Igor.
I was referring to this exchange that happened few years ago. Back then Li had a working prototype and was estimating ~2 months to complete the work.
Nicolas
Sounds great. Mfgtool-SD would be extremely useful not only for mfg but for end-user system updates - if necessary.
What is the anticipated timeframe?
In the i.MX Manufacturing Tool Customization Guide there is a reference to Mfgtools-CD as a preliminary version for Mfgtools. It appears it does what I want to achieve. Booting the unit from SD and loading the OS binaries on the on-board eMMC.
