I'm trying to enable tv in source port in order to capture images from a camera connected to tvin port.
Let me know the steps to enable tv in port and capture images with opencv in python.
Thanks in advance.
Solved! Go to Solution.
Hi ByungGuk
NXP Linux BSPs provides support for tvin as adv7180 support (supports bt656, NTSC, and PAL.)
it may be tested with ..mxc_v4l2_test/mxc_v4l2_tvin in unit test package
imx-test
www.nxp.com/lgfiles/NMG/MAD/YOCTO/imx-test-5.7.tar.gz
For using it with opencv in python, one will have to develop custom solution, probably
one can consider Professional Services to develop custom drivers:
http://www.nxp.com/support/nxp-professional-services:PROFESSIONAL-SERVICE
Hi ByungGuk
imx-test
