LTIB Installation Failed
harshadsinkar
I am trying to install LTIB on my Ubuntu machine and getting the following error:
$./install
You are about to install the LTIB (GNU/Linux Target Image Builder)
Before installing LTIB, you must read and accept the EULA
(End User License Agreement) which will be presented next.
Do you want to continue ? Y|n
Y
Hit enter to continue:
sh: 1: Syntax error: "(" unexpected
I have read and accept the EULA (yes|no):
yes
Use of uninitialized value $_ in pattern match (m//) at ./install line 139.
Cannot extract release tag at ./install line 140.
How to resolve this issue?
Any help is appreciated.
Tags (3)
Yuri
"Building for i.MX Mature Boards"
https://www.nxp.com/docs/en/application-note/AN12024.pdf
Yuri.
fabio_estevam
Hi Harshad,
LTIB is no longer supported. Please use a recent build tool, such as Yocto or Buildroot.
Fabio Estevam
Hi Harshad
please look at ltib installation hints on
Ubuntu 11.10 Oneiric 64-bit Virtual Machine and building i.MX53 L2.6.35-11-09-01
AN3875 Building a Linux Image and Downloading onto i.MX Processors Using a Virtual Machine
https://www.nxp.com/docs/en/application-note/AN3875.pdf
