CodeWarrior for MPC55xx/56xx license on 64bit Windows 7 Host OS
jongcheonkim
Hello. This is Mac.
I saw a note that
' With our classic CodeWarrior IDE products, we do not support USB dongle license configurations for 64 bit Windows 7 and Linux host OS'
but, my customer must use '64 bit Windows 7' Host PC for work.
So, he tries to purchase not 'dongle license' but 'node locked license' for the test PC.
Can he use the 'node locked' CodeWarrior license at '64 bit Windwos 7' PC?
He may use classic IDE version 5.9
Thank you in advance for your answer and have a good day.
Mac.
TomasPaez
Dongle  is not be an option on classic edition, but instead of that they can use their disk serial ID or Ethernet address, use of the dongle is not a showstopper.
My recommendation is to try the install as admin in compatible mode in win 10, try this with the evaluation version and check if the scenario works ok.
https://www.nxp.com/support/developer-resources/software-development-tools/codewarrior-development-t...
ZhangJennie
Hi Kim,
Yes, we can use node lock license with 64bit win7.
Jennie Zhang
