I haven't found any of the RT1052 demo apps using the (semc) external memory controller, is there one floating around?
I tried converting one from a different IDE, but get a hardfault when initializing the SEMC...
Any other help/pointers also welcomed!
Apparently the semc driver demo *is* included with the SDK, it just isn't properly exposed from the import example dialog in MCUXpresso IDE...
See this thread: https://community.nxp.com/thread/467649
If you unzip the SDK you will see quite a few other examples that aren't exposed either.
Thank you!
I was able to get my example working, my problem was the ordering of the memory section for SDRAM for the linker.
