Identify i.MX6 ULL variants via software
lategoodbye
Senior Contributor I
According to the i.MX6 ULL Application Processor Data Sheet (chapter Ordering information) there are several variants of this processor available. Those could be identified by a part differentiator.
So my question, is there some kind of register to identify those variants via software?
Labels (2)
evgenyboger
Turns out, manufacturer bootloader already does the job for you by identifying fused out peripherals and disabling them in Linux devicetree.
Here are the related parts of source code:
uboot-imx.git - Freescale i.MX u-boot Tree
For some weird reason NXP won't openly share the OTP capability fuse table though it's available in the u-boot source cited above.
joanxie
try to find the chapter 57.4.11 Chip Silicon Version (USB_ANALOG_DIGPROG) of imx6ull Reference Manual
https://www.nxp.com/docs/en/reference-manual/IMX6ULLRM.pdf
lategoodbye
Hi Joan,
i don't need chip silicon version (Part A in part number nomenclature), but the part differentator (Part @) in order to know:
How many PWM/CAN/UART/SPI/... interfaces are supported?
Stefan
joanxie
for the interface, you need to refer to the data sheet, different imx6ull chip should have different interface.
lategoodbye
Hi Joan,
you didn't get my intension. For example i want to write a production program which identifies the capabilities of the running processor. I guess these information are hidden in the OTP register.
Stefan
evgenyboger
