Design with HDMI Transmitter TDA19988
malo
I am about to design in the TDA19988. But I got a bit uncertain regarding EOL for this part. No info can be found at nxp.com. The only thing I found was EOL info for the development boards E1TDA19988A (Search Results: tda19988 ).
Also, are there any programming guide for this chip? Or is the datasheet found at mouser all info available?
Magnus
electrodev
I'm in the same boat -- I'd like a technical reference manual and/or information about programming the i2c registers. :smileyhappy:
Apparently you have to sign an NDA for this, according to the support team.
