How to add swupdate to the yocto project and make it be able to build in the images? And I find one direction under SWUpdate: software update for embedded system — Embedded Software Update Documentation 2017.11 docum... , with "Add meta-SWUpdate as usual to your bblayers.conf. You have also to add meta-oe to the list".But when I changed the bblaers.conf and build an image,there comes an issue "swupdate-image.bb No IMAGE_CMD defined for IMAGE_FSTYPES ...."
for this, one can refer to the how to create customer layer document as below:
Sorry, I can't open this url.
try this one:
