Gracefull shut down of microcontroller
vrushalitaklika
I am looking for steps involoved in graceful shutdown of microcontroller when any of the gpio pin is used as key_switch to shutdown microcontroller.
If anyone has idea on sequence of shutting down microcontroller safely, please share your views.
Vrushali
davidtosenovjan
Could you please specify used MCU? Thanks
vrushalitaklika
MPC5777C
davidtosenovjan
You may perform software reset
SIU.SRCR.R = 0x80000000;
in the interrupt routine on external IRQ signal connected to the button
Basically you only need to slightly modify example below:
Example MPC5777C-SIUL_External_IRQ GHS714
vrushalitaklika
Thanks David
