Hi Folks,
We're using a KEAZ128 processor on a new project and I am currently trying to bring tool up with gdb on openocd using a CMSIS_DAP SWD adapter. We use these tools for several other K and LPC series targets.
The info page says:
But I can't get a working configuration. Does anyone know the target config to use or have a working custom one?
Solved! Go to Solution.
Hi Kerry,
Your reply in the other post was incorrect as I was able to get my openocd/gdb environment working fine.. I just had to use a later instance of openocd and the ke0x.cfg configuration. You can see the other thread (as linked in Kerry's post above) for my solutions.
Sorry for posting in two places.
Miller
Hi Kerry,
Miller
Hi Miller,
This question is the same topic as your another post:
Help! Need the correct openocd configuration for KEAZ128.
I have replied you in the above post.
Kerry
