$ JN51xxProgrammer.exe -s COM3 -f AN1211_154_EndD_JN5179.bin
----- Error:reading chip ID-check cabling and power
Failed to read chip details on COM3
Hello wupengfei
You may want to have a look here
https://community.nxp.com/thread/460072
thinks for your help ,I am following your instructions to achieve it。
wupengfei
You are welcome
Please If it worked with you mark it as correct and helpful for others searching on the same problem find the solution easily
If not , comment with any other solution you found to edit and modify the document.
Thanks and Regards
Hi Pengflei,
Could you please check the in the device manager that the JN5179 driver is installed correctly?
Also, if this a custom board make sure you connect the RX of programmer to TX of module and vice versa
VDD, GND, SPIMISO to Ground, RESET to Ground then 3.3v.
Please let me know your findings.
Mario
