Hi, everyone.
I have BeyondStudio for NXP with JN-SW-4168 SDK and JN5169. I'm using a JN-AN-1201 ZigBee Intruder Alarm System application note as a base for my application.
I using my Warning Device send a "Zone Enroll Request" to my Gateway,I received a "Zone Enroll Response" package from Ubiqua,this package is indicated "Enroll Response Code :[0x00] Success" and "Zone ID: 0x01",but my Warning Device receive E_ZCL_CBET_UNHANDLED_EVENT not for E_ZCL_CBET_CLUSTER_CUSTOM in the APP_ZCL_cbGeneralCallback function.Can you give suggestions?
thank you!
Did you write the attributes and send the Enroll response?
This E_ZCL_CBET_UNHANDLED_EVENT only happens with the Zone ID?
Did you try to send the packet in raw data?
Mario
Hello
I also had this question !
Actually I had to switch SDK as no one here answered my question
This is a link to a thread where I asked about this
https://community.nxp.com/thread/444961
I've almost tried everything.
Hoping for some solution finally!
Hi!
I have the exact same problem with the Zone Enrollment process, when the required Zigbee Cluster event won't trigger. And Ubiqua shows perfectly fine Response Code too.
Unfortunately no one answered my question yet, so I have no clue how to fix this. Probably inspecting the raw packet and setting everything manually can work, but that's obviously not the perfect solution.
