Hello All,
I am also trying to boot Linux from QSPI and also tried MFG tool to do the same but MFG tool script allows to copy only u-boot to QSPI as well as QSPI header. I want to burn zImage, device tree & root file system also on QSPI but failed to understand how to do partition of QSPI flash.
Is there any tutorial available for the same. Any help is appreciated.
Niti
Additionally it may be required to configure U-boot environment to boot properly kernel.
Please look at section 4.7.4 (Running the Linux OS image from QuadSPI) in “i.MX_Linux_User's_Guide.pdf”.
Also, please look at the following :
https://community.nxp.com/message/491138
Yuri
