Can't activate LPCxpresso IDE
dfae_banchaolan
I got a problem with LPC IDE
- After install, I'was trying to activate IDE by follow these steps.
: Help->Active->Create serial number and register
Then window pop-up noticed "This will overrwrite your existing registration. Continuous?" Then i clicked Yes
: Serial number show up. Then click ok.
: Then pop-up window show as below. I still click OK
Then browser notice as below.
I'm not sure that mistake from my browser or NXP server. but still can't get activate code. Please help me.
lpcxpresso_supp
I've just checked the LPCXpresso IDE Free activation pages, and they seem to be up and running.
Please make sure you follow the instructions for free activation at:
Activating LPCXpresso Free Edition
in particular you need to make sure that you are logged into the NXP web system.
Note: MCUXpresso IDE (which superseded LPCXpresso IDE back in March), does not require this activation  process for use in Free Edition mode. So you might want to try that instead. For more details see : http://www.nxp.com/mcuxpresso/ide
LPCXpresso IDE Support
