使用CodeWarrior USB TAP无法下载目标文件,
1、在Flash控制器编程控制台中一直提示如下信息
“fl::target -v off -l off
cmdwin::fl::device -d "S29GL128P" -o "8Mx16x1" -a 0xff000000 0xffffffff
cmdwin::fl::protect all off
Beginning Operation ...
Performing target initialization ...
2、在CCS中提示“can't unset "enumIndex_ccs_mode": no such variable
while executing"unset enumIndex_${varBase}"”
Hello wang li,
1. According to the flash programmer log, there is problem with your procedure to do flash programming, please refer to this document for details Flash Programmer for CodeWarrior Power Architecture .
2. If you are bringing up new board, you need to customize CodeWarrior initialization file according to your target board. However it seems that there is syntax error in your CodeWarrior initialization file.
If further assistance is needed, you could send your customized CW initialization file to me to do more investigation.
TIC
