mc9s12 CAN wake up fail
fupeng
    I am using MC9S12xet256 micrcontroller,I use the Processor Expert to create the code.In stop mode, Normally I can wake up it by CAN,but when the AD module added,I can not wake up by CAN.
   Execute the code as follows:
  main.c
for(;;)
   AD1_Measure(TRUE);  /*It is possible to delete these two lines*/
   AD1_GetValue16(&advalue);
   if(EnterStopFlag)
      EnterStopFlag = 0;
      /*turn off led*/
      CAN1_SetSleepRequest();
      Cpu_SetStopMode();
      /*turn on led*/
   event.c
void CAN1_OnFullRxBuffer(void)
   if(MessageID == 0x101)
      EnterStopFlag= 1;
   else
      EnterStopFlag= 0;
void CAN1_OnWakeup(void)
   /* Write your code here ... */
   CAN1_ClearSleepRequest();
Can anybody please help me reolve this issue?
Felix
danielmartynek
Can you attach the project?
fupeng
   When I don't add AD module,I tried many times stop-> wake up ->stop,at last MCU can not be wake up.
danielmartynek
Sorry for the late response.
I have run the project but I don't see any problem.
It always wake up regardless of ADC.
fupeng
I am grateful for your response.
