Hi.
I'm having trouble accessing C/C++ variable from an assembly code.
I have used the following documentation:
assembly programming
and tried to use something like
ASM_KEYWORD(" la r0,branch_addr");
"Load Address (la): The la mnemonic is useful for obtaining the address of a variable specified by name" (EREFRM_2-0.pdf).
Which results in an error:
:113, Error, Unrecognized line: la r0,branch_addr
Is there another way of accessing a variable?
