I want to use MPC5744P to configure a chip through SPI.
I need to configure the register of the chip through SPI.
My problem is how to configure the register in a certain address through SPI?
Is there some demos?
thank you
Which chip you have on your mind?
Maybe you will find a solution in following thread:
I am using A4412 and A4916 chips, which are from Allegro.
