How To flash fresh FRDM-LS1012A with empty flash?
shyam_baldha
Hello Community,
1. How to Flash fresh FRDM-LS1012A board which is not having any binaries (RCW, U-BOOT, KERNAL IMAGE)?     Exactly what are the tools needed and what procedure to follow?
2. Can some one point me to the documents, for how to use below listed tool for FRDM-LS1012A board:
         - Code warrior
         - Code warrior - TAP
         - QCVS
3. Which tool is to be used for flashing CMSIS-DAP binary? and Information/documents to use that tool.
Shyam
ufedor
Which exactly board is in question?
shyam_baldha
LS1012A freedom board.
ufedor
Why it is "fresh"?
It has to be fully programmed during manufacturing.
shyam_baldha
We are Designing a customized board by taking reference of FRDM-LS1012A board with some few changes.  So I need to do all booting processes to bring-up custom board which having empty flash.
ufedor
Please create a Technical Case for each of the numbered sections - refer to the following link:
https://community.freescale.com/thread/381898
