Can you give me a example about it which to create a library?Thank you very much.
Solved! Go to Solution.
unfortunately, I do not have example for this case, but all necessary information are described in the document in the attachment. Please look at chapter Command-Line for Power Architecture Processors especially check switch -library.
Martin
