IMX6q 上添加tw6865芯片时注册失败
joubertshe
Now we need add tw6865 ic to imx6q board,
but when start kernel tw6865 prob could be failed,
and the log file indicated that can't enable device BAR0 not claimed,
i have uploaded the log picture as attachment, please help check this issue , thanks a lot
Tags (2)
tengri
This could be due to hardware connection issues between IMX6Q and the chip. Which kernel and distribution you use? Couple of things you can try in the kernel to tweak :
1. Try disabling PCI Force Gen 1 option in menuconfig
2. Also disable PCIE MSI Signal Interrupt Option
Anuradha
joanxie
pls refer to the topic here:
https://community.nxp.com/thread/444870
joanxie
pls refer to the link as below, you can refer to the software path.
https://community.nxp.com/docs/DOC-94541
