MK24FN256 missing in processor expert
jensmadsen
I have downloaded download Driver Suite v10.4, but it does not seem to support MK24FN256 cpu. The CPU is used in TWR-K24F120M. I am not able to find any processor expert support for it. Only MK24FN1M0 is shown in processor expert. I use KDS 3.2.
Hello Jens,
Yes, the Processor Expert don't support the chip of MK24FN256, for the Processor Expert
won't support new products. For kinetis , we suggest to use KSDK(the new name is MCUXpresso SDK).
Now there are two methods to develop it on KDS:
1) Install KSDKv1.3 on KDS, it  support it's own Processor Expert, about the download and install
please refer to the KDS_Users_Guide.pdf ->Installing Kinestis SDK.
2) The new version of KSDK is KSDKv2.x (MCUXpresso SDK), it didn't support Processor Expert, while there is
MCUXpresso configure tools , also I recommend you use this version, for the new products will
all be supported . About the detail please check MCUXpresso Software and Tools for ARM® Cortex®-M cores|NXP
And about how to use KSDKv2.x(MCUXpresso SDK) on KDS , please refer to :
Using Kinetis Design Studio v3.x with Kinetis SDK v2.0
Hope it helps
TIC
Hello Jens,
Hope it helps
TIC
carloshass
Alice,
In Procesor Expert supports https://www.nxp.com/part/MK22FX512VLL12, but now, it's under "Not Recommended for New Designs" and was substituted by MK22FX512AVLL12 (not supported by PEX).
There´s anything i can do to not lost our project in KDS with PEX ?
CH
Hello Carlos,
If your project is new, you can choose MCUXpresso IDE,
MCUXpresso IDE|NXP
it  also can configure  peripherals, while it is not the same with PEx.
Alice
Hi Carlos,
I think you can also develop  MK22FX512AVLL12 using  MK22FX512VLL12 option on PEx.
For the "A" just a Revision , you can have a look at the Data Sheet :
Hope it helps
TIC
