Dear all,
The configuration for 16bit VYUY is below in mxc_ipu.
unfortunately, mx6 doesn't support 20bits output. only solution is that you can connect mx6 16bits to the two high 8bits of display, the two low 2bits connect to ground, then you can refer to the patch in the link as below:
