HotFix_1: Fix license errors for DISK_SERIAL_NUM with less than 8 characters
NXP Tracking number: AST-619
Problem: If your HDD has a serial number with less than 8 characters, the license checking and validation will fail even if the license is correctly generated
Root Cause: Coding logic error
Workaround: Update the files attached in the following folders
{Toolbox install dir}\mbdtbx_S32K\mbdtbx_s32k\mscripts\checkers\ folder mbd_s32k_cc_data_check.p file
{Toolbox install dir}\mbdtbx_S32K\mbdtbx_s32k\mscripts\matlab_ui\ forder mbd_s32k_hostid.p file
Customer Report: The error of Matlab Motor Control Toolbox for MATLAB / Simulink MBD supporting S32K1.0 library
Special thanks to Bin Qin for testing and fix confirmation
Original Attachment has been moved to: mbd_s32k_cc_data_check.p.zip
Original Attachment has been moved to: mbd_s32k_hostid.p.zip
