I encounter a weird problem with my custom imx6ul board.
The system boot normally (we are using Buildroot based solution) but hangs EXACTLY in 600 seconds after the OS takes its control.
U-Boot does not have such behaviour, it lasts until reset or power off.
I tried to rebuild Linux kernel in different ways, clocks, idle, power modes but there is no effect on it.
Don't think it's a kind of HW issues, all power rails looks stable, clocks are preset.
Any ideas?
Thank you
Solved! Go to Solution.
Hi Alexander
this can be lcd automatic blanking
LCD turning white after a few minutes
Hi Alexander
Hi Igor,
You are correct, this is LCD blanking! Thank you!
Alexander
