MPC5604S - PCR register update Issue
akhilprasad
I am using MPC5604s controller and eclipse based code warrior IDE.
- CodeWarrior for MCU
Version: 10.7
Build Id:160721
When I try to configure
SIU.PCR[98].R = 0x0200 and
SIU.PCR[97].R = 0x0200,
then in the register view its not getting reflected. Its showing 0x0000
Please find the screenshot attached.
Is this issues related to IDE and debugger or with my code ? Kindly guide me.
martin_kovar
could you please send me your project? Which debug probe you use?
I tried with Lauterbach debugger with the project below and it worked correct on my side.
https://community.nxp.com/docs/DOC-334202
Martin
