We use this register to write a value to communicate between our bootloader and recoveryOS. It works fine in the solo and in the imx6D 1.2. The same software is not working in the imx6D 1.3. If I try to write to the register it always reads back a 0. I also checked that neither lock bits are set. What could be wrong?
Please check if software changes / patches, mentioned in the EB803 are applied
in Your case.
http://www.nxp.com/assets/documents/data/en/engineering-bulletins/EB803.pdf
Yuri
Yuri,
I did look at those, but I don't see that they could possibly have anything to do with the SNVS_LP register.
The mentioned patches should be applied (actual) in order to avoid software side effects.
Is SNVS voltage proper and satisfies power up sequence ?
Yuri.
