Problem: Can't download program (to TWR-K60D100M) with MCUXpresso-IDE
jerrylian
I just run MCUXpresso-SDK example programs on board TWR-K60D100M:
* When I compiled and debugged, it runs well as specified in documentation
* But when I stop debugging, the example program won't work anymore.
* Even if we unplug/replug the board, the example program still won't work.
So: how can we download the program PERMANENTLY to the board with MCUXpresso-IDE?
Thanks!
Carlos_Mendoza
Hi Jerry,
It seems that you have semihosting enabled, please take a look to this thread:
https://community.nxp.com/thread/448272
Hope it helps!
Carlos Mendoza
Technical Support Engineer
lpcxpresso_supp
You might have noticed semihosted I/O requires its' own library. The semihosting mechanism requires interaction by the debugger to process a BKPT exception to display I/O in the console view. If the debugger is not connected, the BKPT exception is otherwise not handled. Here's more information:
What is Semihosting?
Thanks and regards,
LPCXpresso Support
Carlos_Mendoza
Hi Jerry,
Hope it helps!
Carlos Mendoza
jerrylian
Hi, Carlos:
Yes, it works, Thanks a lot!
* But shouldn't it be disabled by default? I guess most new users don't know the trick.
By the way, do you know why my post doesn't show up under "Overview" tab (it only shows up under "Content" tab).
* Post showing up under "Overview" draws more attention, right?
Thanks!
Jerry
ZhangJennie
Hi Jerry,
Thanks for your proposal. I would like to suggest you create a feature request for this feature.
How to submit a new question for NXP Support
Personally I think  it would be good to have a short description for "semihosting enabled" in the page. Thus users will not overlook it easily.
your question " why my post doesn't show up under "Overview" tab". Normally if a thread get a new update, it will be posted to the top item in the "Overview" tab automatically.
Jennie Zhang
ZhangJennie
Here you can see your post went to upside after my previous post.
jerrylian
Hi, Jennie:
Thanks for your explanations. I will submit a feature request later.
Jerry
