For the component 74HC595D,I want to know the Pin 1 index is a pit or circular silkscreen on the top silkscreen side.
The distributor tell us that the pin 1 index of 74HC595D has two types,one type is a pit on the top silkscreen side,the other type is a circular silkscreen on the top silkscreen side.We only want to check the distributor said is correct or not.
Thanks for your inquiry. This question is related to the Standard Products business. We would like to inform you that NXP has divested it´s Standard Products business on Feb 6th 2017. This new standalone company is called “Nexperia”, headquartered in the Netherlands, and is a world-class leader in Discretes, Logic and MOSFETs.
We would like to ask you to re-enter your inquiry at the Nexperia support web page: www.nexperia.com/support. Thank you!
Tomas
