How I write only 4 byte in flash memory? I'm using S32k144.
There is a flash example, which shows how to erase/program the flash, in the document section of this page.
The minimum you can write is an 8-byte phrase.
You can fill the rest of bytes (FCCOB registers) you don’t want to write to with 0xFF.
