I am using the TWR-VF65GS10 board currently and will write a hardware description to customer. But i don't know how to read the revision of the board, which label on pcb should i read as board revision? Thanks!
Add information:
There are three labels on the back of the board.
SCH-27442 REVH - I think this should be schematic revision
RV14210237
700-27442 REV J1
Solved! Go to Solution.
SCH-27442 REVH - schematic revision.
700-27442 REV J1 - board revision.
Yuri
Note: If this post answers your question, please click the Correct Answer
button. Thank you!
Yuri
button. Thank you!
Thank you very much
