We are new to the android development. We want to integrate the PN5180 on IMX6 Sololite with KITKAT 4.4.3 OS.
If any documents or any user guide is available then appreciated.
Thanks in advance.
Hello Devi Lavanya Andaluri,
Application Note 11802 (link below) has the NFC Reader Library Installation Guidelines and although it does not cover Android per se it should help as a starting point.
http://www.nxp.com/documents/application_note/AN11802.pdf
Perhaps AN11906 may also be of help:
http://www.nxp.com/documents/application_note/AN11906.pdf
There is a Community Document covering the PN7120/7150 for the i.MX6SX that may also be useful.
https://community.nxp.com/docs/DOC-331906
I hope this information helps!
