I am trying to get our software to compile on KDS. We are using a Kinetis K70 processor and MQX. Some of our code makes use of STL (the Standard Template Library), things like std::list and std::string. However I keep on getting errors when I compile in KDS, similar to these:
Does anyone have an idea what the problem could be, or how I could get around these issues?
Any help would be appreciated. Thanks.
Hi Jim Gagne:
STL is a software library for the C++ programming language, I think MQX projects need to be a little bit adapted to properly build with C++ code. You can refer to the attached document Creating a New MQX Project Using GCC and C++.
