Hello Community
About registers IOMUXC_SW_PAD_CTL_PAD_DRAM_ADDRxx of i.MX6, I have some questions.
1)DSE needs to be configured and ODT does not need to be configured(just set ODT to 000), is it right?
2)If 1) is not right, how should ODT be configured?
Best Regards
ZongbiaoLiao
Solved! Go to Solution.
Please refer to the following : ODT setting for i.MX6UL
Yuri
Note: If this post answers your question, please click the Correct Answer
button. Thank you!
Yuri
button. Thank you!
Hi Yuri
Thank you for your answer!
ZongbiaoLiao
