Same memory map of Cortex-M4 in i.MX7D
ko-hey
Senior Contributor II
Hi all
Let me confirm about memory map of cortex-M4 in i.MX7D.
There are same memory map description which has different memory address.
Please see the following red square.
Can user use as different region ?
If yes, please tell me about the division of use.
Ko-hey
Labels (2)
joanxie
this different address is CM4 ALIAS SYSTEM, you can refer to the application note to get more detailed information:
<http://www.nxp.com/assets/documents/data/en/application-notes/AN5317.pdf?&fsrch=1&sr=1&pageNum=1 >.
joanxie
ko-hey
Thank you !
Ko-hey
ko-hey
Could someone follow and answer this question ?
Ko-hey
