Could you please help me with clear step by step procedure to minimize the boot up time.
The information in the link https://community.nxp.com/docs/DOC-93619 is not very clear for me.
You can refer to the above link, it's really can help you. When you meet problem you can tell us detail quesitons, we can give you method to solve it.
Have a nice day
Rita
Hi Rita,
I am using sabre imx6 board.
I am trying to reduce the bootup time by removing unwanted driver init from kernel.
I have fallowed the below steps to build.
$ repo init -u git://git.freescale.com/imx/fsl-arm-yocto-bsp.git -b imx-4.1.15-1.0.0_ga
$ DISTRO=fsl-imx-wayland MACHINE=imx6qsabreauto source fsl-setup-release.sh –b build-wayland
$ Bitbake fsl-image-qt5
we are using .sdcard image.
$ bitbake linux-imx -c cleansstate
$ bitbake linux-imx -c cleansall
$ bitbake linux-imx -c menuconfig
change the configuration save and exit.
copy the .config to defconfig.
$ cp build/tmp/work/imx6qsabresd-poky-linux-gnueabi/linux-imx/4.1.15-r0/build/.config
/sources/meta-fsl-arm/recipes-kernel/linux/linux-imx-3.14.38/imx/defconfig
$ bitbake fsl-image-qt5
But I dont see any changes in the kernel initialization.
Please let me know proper methods to implement this.
Rajath
