How much RAM is required for LWIP? as of now my application is using 24Kb, can't we reduce that? any option available to merge two SRAM's in lpc1769?how to use contiguous memory blocks for heap in LPC1769 by using two SRAM's?
edigavenkappa
HI,
How to utilize two SRAM for HEAP?
how much heap is enough for LWIP?
Carlos_Mendoza
Hi Ediga,
Take a look to the following document for some examples of the LWIP memory requirements:
The heap size can be setup by changing the Heap_Size value in the startup code. Please notice that LWIP uses it's own run-time memory allocation functions, not the heap defined in the startup code. However, FreeRTOS allocates task stacks, mutexes, semaphores, etc. from the heap defined here.
Regarding the heap allocation, please take a look to the following thread:
https://community.nxp.com/message/808127
Hope it helps!
Carlos Mendoza
Technical Support Engineer
