init      Linker Generated Symbol File
wanglong
在rom.map没有这个是为什么?
wanglong
Boot Assist Module (BAM) with FlexCAN MPC5534
Hello !
I need to use the Boot Assist Module to boot an application from FlexCan bust to internal SRAM.
 I  modify the start.c,but my rom.mot is not use.
Can help me with a example code? Just I have to modify the Linker Files?
Thank you very much for your time!
lukaszadrapa
Please do not duplicate the threads. Follow https://community.nxp.com/thread/443190
wanglong
Hi, I met a problem when I was using mpc5634, and I generated ram.mot files on the way you provided, but my application didn't run on ram! What's the reason? Can help me? Thank you for your。
martin_kovar
at first, could you please write your question in English? Second, the question does not make any sense to me. Could you please clarify it?
Martin
