Is there any way to use gprof with an LPCXpresso5411x board (with or without the lpcxpresso IDE)? I found the following tool:
/Applications/lpcxpresso_8.2.2_650/lpcxpresso/tools/bin/arm-none-eabi-gprof
and wonder if I would be able to use it in certain way. Thanks.
Or if not, is there any profiling tool available?
We haven't used gprof in this manner. But I suggest that you take a look at the SWO Trace functionality in LPCXpresso IDE which will give you profiling based on PC sampling ...
Overview of Trace support in LPCXpresso IDE
LPCXpresso Support
