I appear to be experiencing the issue described here with LPCXpresso 8.2.2 on macOS Sierra 10.12.2. I completely reinstalled the program by deleting the LPCXpresso directory in /Applications/, /Users/Shared/NXPLPCXpresso/, and my workspace. I then reran the installer and activated according to the directions but the issue is still present. The NXPLPCXpresso directory and log file is attached.
Original Attachment has been moved to: NXPLPCXpresso.zip
We can't replicate any problem here on our macOS 10.12.2 installs.
Whilst we check out your license files in more detail, please can you also:
Can you also confirm if this is an activation you were previous using successfully (potentially on an earlier version of macOS) or did you generate your serial number / activation code after installing Sierra and have never made it work?
LPCXpresso Support
