(Sorry if my english sucks, I hope you'll understand)
So i'm in internship and i'm working on a project. So I got a problem when I build the project. Everything is fine, I don't have any errors on the code but I got this at the end : make: ***[Test_UART_v1.axf] Error 1. So I know that the problem is from the sprintf because when I delete it, everything works.
I'll just put the part with the sprintf :
#include stdio.h
int voltage = ADC_Read(); //function created by myself
char volt_final[10];
sprintf(vol_final,"%d",voltage);
So I read some articles about the librairies and I'm new to LPCXpresso so maybe I need to do something ?
I tried itoa but it doesnt seems to work, I don't get a good result ,maybe I did something wrong with my ADC_Read().
Thank you for your help :smileyhappy:
Solved! Go to Solution.
To use sprintf, you need to make sure that you are building against the "Nohost" or "Semihost" variants of the C library. For more information see:
What are none, nohost and semihost libraries?
Switching the selected C library
Linker error "Undefined reference to 'xxx' "
If you need more assistance, please post full details of the error message(s) that you get in the build log:
https://community.nxp.com/message/630853
LPCXpresso Support
LPCXpresso Support
Perfect, thank you very much ! The 2 articles were usefull and I understand now :smileyhappy:.
