I want to know about availability of CodeWarrior IDE ver. 5.9.0. for HC08 core microcontroller.
Also if it is available then where can I get its evaluation version to download?
can I install IDE 5.9.0 on Windows7 ?
Thanking you,
Hello Sarang,
It doesn't support the Win7,
CodeWarrior for Microcontrollers-Classic IDE|NXP
There is a DOC about how to install it on Win7,you can have a try.
https://community.nxp.com/message/310577
Hope it helps
Alice Yang
Hello Alice
Thank you for your support.
I am not yet sure whether IDE 6.3 supports HC08 processor like (MC68HC908AZ60) bcos it is not mentioned clearly in link you provided. Can you see it in Microcontroller list of IDE? please let me know....
Hello Sarang,
The CodeWarrior 6.3 is the CW IDE version 5.9 just like you said.
And yes, it support this chip : MC68HC908AZ60.
You can see this in the linker i mentioned :
Also i check the IDE :
Alice Yang
Hello Alice
Thank you very much for your support. It is clear now on IDE version.
Only one query: I have Windows 7 on my computer so I have to refer following link you suggested
Have you tried to install IDE 6.3 on windows 7 by following procedure mentioned in above link?
Does IDE work faithfully if installed by this procedure ?
Sarang
Hi Sarang,
Sorry , no, i haven't test it .
Alice
Hello Alice
Thank you very much for reply.
But I doubt that V10.7 Support HC08 Microcontroller. IDE 10.7 support S08, and HC(S)08 not HC08.
It seems it is only IDE 5.9.0. which has support for HC08 core .
But does IDE5.9.0. exist? or is it discontinued? please let me know.
Hello Sarang,
Sorry for the reply i have deleted, i unexpected you received it so quickly , please ignore it .
Please refer to the response i just send to you .
Alice
