K22Fx512 example code
mayursavaj
Hi Everyone.
We are using MK22Fx512 controller. We are using Code warrior as IDE.
I need example code for below to kick start new project.
1) LED Blink
2) all interrupt enable/disable
3) Timer program
4) setting Timer interrupt
Thanks in advance.
Robin_Shen
We recommend you using Kinetis Design Studio IDE.  CodeWarrior IDE Support to Change for Kinetis® Devices. Read More
There are many examples in SDK_2.0_MK22FX512xxx12. You can select and download it.
You can getting start with KSDK and KDS from reading below:
 "How to start with KSDK"  and "KDS Document List".
Robin
mjbcswitzerland
Specialist V
http://www.utasker.com/kinetis/FRDM-K22F.html
http://www.utasker.com/kinetis/TWR-K22F120M.html
Builds with CW (or KDS, IAR, Keil, Atollic, Rowley, Green Hills, CooCox, GCC, VS) - including (approx.) real-time K22 simulator.
Complete project code to do what you want (plus SD card, USB host and device, etc.). Industrial proven framework with production quality code and not just examples....
Documents, videos and tutorials to start and finish any project faster and more reliably (with compatibility across Kinetis devices in case the processor is changed in the future).
Mark
