I am developing for the MPC5777M with S32 Design Studio. I am using Processor Expert Software - RAppID Suite v10.2.1 for processor initialization. I am inquiring how these two programs should be used together. In the past, processor expert has been integrated into Code Warrior, but Code Warrior does not support Power PC architecture processors. Here is my understanding of the separate programs, and where I have a loss as to how to use them together:
As the user, how am I expected to treat these tools? Here are my ideas thus far:
I have attached two images with the respective programs project hierarchal differences. Are there any plans to integrate Processor Expert into S32 DS? It just seems as though the project generated by PE is meant to be used a single project, where as S32 DS has a project for each core.
Thank you kindly for your help in the matter.
Eric
Hello Eric,
Sorry about the delay.
PE RAppID Suite is not officially designed to work with S32 Design Studio and unfortunately there is no plan to integrate RAppID Suite with S32 DS as far as I know.
Anyway, there is a workaround which might help to use these tools together. It has some limitations but at least it may help with initialization part.
I created an example and posted it on community:
https://community.nxp.com/docs/DOC-333514
Please let me know if you have any comment or question.
Hope it helps.
Stan
