Hi All,
We have a requirement of 1080p30 video encode into h264 using the imxvpuenc_h264 gstreamer module. Our processor is IMX6Duallite. We plan to put 512 MB ram in our custom board. Is it possible to encode with 512 MB ram ? . How to see the memory usage of encoder/decoder (VPU and GPU elements). Any system calls for this ?
Solved! Go to Solution.
Hi anjo
Try nxp vpuenc (part of nxp/fsl gstreamer plugins fsl-gst-plugin),
details are :
http://trac.gateworks.com/wiki/Yocto/gstreamer
https://community.freescale.com/thread/376271
also, usage described in your bsp documentation Linux Guide sect.7.3.3 Video encoding,
For memory profiling, you can try this as base:
IMX6 Memory Bandwidth usage - RidgeRun Developer Connection
hope this helps
Hi anjo
details are :
hope this helps
