Hi All,
I am working on I.MX6 sabre board Quad now with a demo to display picture in picture with 2 camera inputs.
The demo is working and I even can swap the foreground and the background video on the fly.
But the foreground window is always transparent no matter which video input is from.
I used global alpha to make one video output to be opaque. But in this way, the other video output window is hidden when this one becomes the background.
Is there a way that I can change global alpha or turn off/on it on the fly?
The demo that I want to do is picture in picture, the foreground one is opaque, and swap the foreground and the background video on the fly.
Thanks!!
Ivy
Solved! Go to Solution.
Please look at the IPU examples
ipu-examples release notes - v0.1
https://community.nxp.com/message/403343
Yuri
Note: If this post answers your question, please click the Correct
Answer button. Thank you!
Yuri
Hi Yuri,
I found a way to do it.
Thank you very much!!!
Ivy
Hi Yuri,
For resize I mean resize the overlay screen, not the output screen.
Thanks and Best Regards,
Ivy
Hi Yuri,
Thank you very much for your reply.
The IPU example is changing an overlay's alpha on the fly.
I tried to use this way. But it looks like I can not put another camera input as an overlay.
Can I put another camera input as an overlay? If I can, how can I resize it to a smaller window?
The way I already did to support Dual camera is to let one camera input display on video16, and another one on video17 without using overlay.
Is there a way to change global alpha on the fly without using overlay?
Ivy
