How to change i.MX6 CPU frequency
frankchenmh
Hi, I use i.MX6 Android KK4.4.2 BSP. I noticed the CPU run at 792MHz because I can see the following message when uboot boots up:
CPU: Freescale i.MX6 family TO1.5 at 792 MHz
Could anyone let me know how to change i.MX6 CPU frequency to 1GHz or 1.2GHz? Thanks!
Labels (5)
Rita_Wang
Hi Frank,
Which i.mx6 processor are you using? Firstly, you need to confirm if it support 1.2Ghz work.
About how to change you can refer to the follow thread:
How can I change CPU frequency on i.MX6Q ?
Change CPU frequency
https://community.nxp.com/message/662973
Hope this can help you. Any questions you can conact me.
Rita
frankchenmh
Hi Rita,
Thanks for you reply! I can now change CPU frequency to 1GHz based on your info. I will study if it can be changed to 1.2GHz.
We have some i.MX6Q chips which support 1.2GHz.
