Hello all.
I try to boot Android via TFTP & NFS.
I have successfully boot kernel and dtb via TFTP and successfully mount rootfs on NFS.
boot log in attachment.
I see that android have access to NFS root and create there directories and change permissions, but booting hangs on:
warning: `zygote' uses 32-bit capabilities (legacy support in use)
and after this in console I receive messages with 10 sec period
request_suspend_state: wakeup (3->0) at 29171553335 (2016-10-20 12:52:32.108244336 UTC)
request_suspend_state: wakeup (0->0) at 37921858670 (2016-10-20 12:52:40.858550337 UTC)
request_suspend_state: wakeup (0->0) at 46851544004 (2016-10-20 12:52:49.788235005 UTC)
request_suspend_state: wakeup (0->0) at 55541579005 (2016-10-20 12:52:58.478270006 UTC)
On display a see bootanimation. If I stop it nothing changes.
Can someone give me some hints to solve this issue?
Original Attachment has been moved to: Android-NFS-boot.txt.zip
Solved! Go to Solution.
Hello, you post was useful for me. I move setprop ro.nfs.mode yes from init.freescale.rc to init.rc and Android boots successfully via TFTP & NFS.
Thank you.
Thank you.
