hi,
I have a imx6qp sabre ai board for which the build system with "meta-ivi" is ready but when i try to build the "devicemanager" module i am getting the below error:
ERROR:|
/home/pase/freescale/fsl-release-ivi/build2/tmp/sysroots/imx6qpsabreauto/usr/include/gnu/stubs.h:7:29: fatal error: gnu/stubs-soft.h: No such file or directory
also find the bilow error log file:
Please help.
Lavakumar S
Original Attachment has been moved to: log.do_compile.17057.zip
pls check if you use CC instead of $CC , I send the link to you for reference, hope helpful for you.
Yocto dizzy version 1.7.1 cross compiling meta-toolchain BROKEN for weeks now!
